1999 Acura RL Headlight issue
Old Apr 21, 2013 | 09:14 PM
kzookid's Avatar
Default 1999 Acura RL Headlight issue
Hello,
I still love my Acura which I purchased with 39k miles on it and I am now rolling with 260k
My goal is to take it to 300k which will give me another 2.5 years but I need some help/advice. My question:
I have a headlight that works itermittently. The last time I purchased those headlights, I was told they last approximately 7 years. When I see that the light is out, I can turn the lights off and on and then it comes back on. Sometimes it stays on for the rest of the trip or sometimes I have to turn the lights on and off several times to get the light working. Anybody had that issue? Could there be another issue that is causing the intermittent behavior?
Old Jun 5, 2013 | 10:20 AM
WilsonHenry's Avatar
Originally Posted by kzookid
Hello,
hid xenon kits, I was told they last approximately 7 years. When I see that the light is out, I can turn the lights off and on and then it comes back on. Sometimes it stays on for the rest of the trip or sometimes I have to turn the lights on and off several times to get the light working. Anybody had that issue? Could there be another issue that is causing the intermittent behavior?
Never heard of such problem. Could be huge wiring problem but surely you need expert help to solve it...
Old Jun 12, 2013 | 02:02 AM
Check your ground wire that grounds out that headlight to see if there is corriosion at the ground wire itself.
Old Jun 24, 2013 | 10:56 AM
Anonymous58's Avatar
If you need a professional to help solve your problem, you could head to Precision Inc. in Tucson Arizona. They specialize in Honda and Acura repair. If you want more information, here is their website where you can schedule appointments: http://www.tucsonprecisionservice.com
Old Jul 24, 2013 | 01:22 PM
kzookid's Avatar
Default Headlight Issue
Big Thanks to WilsonHenry and WheelBrokerAng for responding to my question. WBAng, I asked the service tech to take a look and what they found was a connection that wasn't tight so they thought they had it fixed. It started doing it again so it might be a bigger deal as they thought they fixed it.
Thanks for the suggestion though. Much cheaper than one of those expensive lights......
Old Jul 27, 2013 | 11:42 AM
poorman212's Avatar
Super Moderator
When it goes out....any chance you could check for voltage and ground on the wires to the light?
I know they said the light will last 7 years but they could be wrong. A filiment could be bad causing intermit issues
wendtdc13
Aug 23, 2012 07:58 PM
TheForilla
Feb 1, 2012 10:54 AM
sundevils010
Dec 3, 2010 05:52 PM
jenwahi
Apr 14, 2010 09:59 PM
justin96
Nov 28, 2006 02:12 AM
