1996 RL Window Motor
Driver side rear window seems to have come off track or something and won't roll up. Motor still runs, and makes rattling and crunching noises as it gets to the top or bottom of its run. Window can be moved up and down easily by hand but will not go all the way up. I have the door panel off and can't really see in there to see what's going on. Any ideas on what the prob is, how to fix it, and how hard of a job this is? Thanks....
The problem is most likely the window regulator. There is a small white pulley that gets mangled. Very common in early RLs. Happened to both of my rear windows. Poor design.
There are some for sale on ebay. Check some of the other forums for more info: acuraworld.com, acura-legend.com |
This not right to drive without having a proper rear view. This can be horrible for you as well as the others. Go and have it repaired. Dont neglect it.
You can take it to a dealer. He will be the best person to help.
Originally Posted by seamusNH
(Post 9148)
There are some for sale on ebay. Check some of the other forums for more info: acuraworld.com, acura-legend.com Philanthropist....my view is not blocked at all. But thanks.... Aliyork....this is a job I can do myself....if I can get the right part. Thanks! |
1 Attachment(s)
Here is a pic of the two parts, the left one being the one I took from the car.
(Post 9148)
The problem is most likely the window regulator parts. There is a small white pulley that gets mangled. Very common in early RLs. Happened to both of my rear windows. Poor design.
Originally Posted by ndrewoods
(Post 13196)
Bump. +1. Experienced this before and it was such a headache looking for what the main culprit is. I soon found out that it is the regulator motor that is wrong. Try looking at JCWhitney for parts. Best of luck.
Shouldn't be an expensive fix. You can get motors at a junkyard for not that much.
Originally Posted by coloradowest
(Post 9471)
