19’s or 20’s
Old 10-27-2005, 02:14 AM
mannysrl's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Does anyone know what 19's or 20's will fit the 2005 RL?
Old 10-28-2005, 01:46 PM
Patrick's Avatar
Administrator
there are so many wheel companies, im sure that you will just have to find a wheel that you like. i think that your biggest issue is going to be clearance in turning.
Old 10-31-2005, 03:26 AM
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
//--></>Call up Symbolic Wheels in Calif , they will set you up with the correct fitments that wont rub your fender wells...
WheelBrokerAng[img]smileys/smiley16.gif[/img]
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
</>Edited by: WheelBrokerAng
Old 11-14-2005, 01:50 PM
Patrick's Avatar
Administrator
Old 11-15-2005, 03:23 PM
mannysrl's Avatar
I found a set of 20" Niche F-18's. I will post a picture soon. They look pretty cool.Thanks for your reply's.
Old 11-16-2005, 03:02 PM
Patrick's Avatar
Administrator
i look forward to it!! [img]smileys/smiley1.gif[/img]
Old 03-11-2007, 10:04 PM
revelyn282's Avatar
Hope you found your wheels.I have a 01 tl and would like to buy a 05 RL in the spring. How has your luck been with the car?
Old 05-22-2007, 11:09 PM
Hurley42385's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
I own a 02' RL and I have 20 x 8.5's with a 235/35/20 tire. I am almost positive that with a 7.5" wide rim you should be fine. i had the fenders rolled and locking spring spacers on the rear and i hardly ever scrub. Car came with the wheels so i didn't have a choice. Nice though. Vault Wave's.
  #9
Old 05-25-2007, 09:47 PM
Hi:
Yes 19" and 20" will fir your RL 3.5, the sizes are as follows :
19 " 5x120mm , Hub size 64.1 , Tire size - 245/40/19 , Offset between 42 to 55 mm
20" all figures are the same except for the tires which go to this here size 255/35/20
Hope this info has helped you out...
  #10
Old 10-18-2007, 06:34 PM
Scott's Avatar
Hi you got to know a bit about your suspension to figure out what might work or not. A good place is tirerack. com they havegreat informtionand i might add good tire prices as well.get information about your fitment, off set stuff like that then look for wheels. My view once you know what fits look for wheels that fit those demensions. don't take anyones word they could be wrong.I did my research then found wheels that fit the bill and saved bokoo bucks.
happy hunting
aeb10574
02-26-2009 05:47 PM
Quick Reply: 19’s or 20’s
