HELP Has anyone else experienced a shutter - rear shimmy - hard to explain. I experience it on rough roads - rear seems to want to "kick out". Also experience on icy snow covered roads - alway compensating steering wheel to keep straight. Its an 05 RL with 45k - dealer says suspension is solid. Tires are all seasons with 75% tread. Any input will be apreciated |
ok you have a hard bump shimmy...and solid suspension.
then you have a dealer that isnt taking the time to find this problem. you have a vehicle control issue. TOP priority in my book. but. if you have a second set of tire, then get those put on and see if it stops. if you dont then get them rotated and see if you "shimmy/kickout" moves to the front. i suspect you have a shock with a worn spot in the center of its travel. its not leaking and wont look like a bad shock. if it kicks to the passenger side i would suspect the right rear shock. if driver side i would look into the left shock. i suspect you have a dealer that isnt doing there job. |
Great advice - thanks for taking the time. I thought it was a shock/strut issue also but dealer saw no sign of leakage and dismissed as a cause of problem. I will approach them again. |
Take it to a suspension shop instead..
| All times are GMT -5. The time now is 07:11 AM. |
