Electrical problem?
2017 Acura RDX, no problems until about a month ago. I was in park, it acted like it was going to stall but did not. However, the dash lost power, the VEHICLE STABILITY ASSIST message flashed for a moment on the screen then was gone. I turned the steering wheel (still in park) and every time I turned it, the dash would lose power, same message would flash. It is very inconsistent, because after I turned the engine off, restarted it, the problem did not happen again. It has been happening sporadically over the past month, no pattern or warning, sometimes it happens when I'm idle at a stop light, but it's not consistent at all. I took it in to run diagnostics, no codes came up. Mechanic could not reproduce the problem.
Anyone have any clues as to what is happening? I would love to address the problem before I get stuck on a freeway in Houston! Thanks in advance for your help! |
| All times are GMT -5. The time now is 05:15 AM. |
