Audio Information Screen Blank 2013 RDX
Good Morning again!
So, I continue to have issues after the installation of a Dashcam on my wife's 2013 Acura RDX AWD. The plus side of this, is that she may never let me work on her car again! The downside, is that her Audio Information Screen is now blank (after everything was working just fine after the dashcam install for a couple days) and radio doesn't work. I've tried pulling the negative battery terminal trying to reset everything ( I do have the radio code if I can ever get the screen to work). This vehilcle DOES NOT have Navigation. I've checked Fuse # 12 (Accessory Power Socket Center Console) and Fuse # 27 (Accessory Power Socket Front), and both fuses are good. However, I DO NOT have any power at either of those power sockets nor from the USB Audio Pigtail in the Front Console area. Are there any other fuses between Fuse 12 / 27 and the Audio Information Screen and the Console Power Sockets? Could really use some help on this one! UPDATE: Ok, I'm an idiot! At some point, I must have removed Fuse #19 (Listed as ACC) as one of the Fuse Slots to tap into for the Dashcam that is switched power. As the OBD or CAN systems seemed to be VERY Sensitive to me tapping into some of the available/open Fuse Slots on the Fuse Panel,, I did not "Close" the circuit by adding a fuse to the bottom part of the Add-A-Fuse Tap so I didn't complete the circuit, but only used the power from the line side ot run the camera. Without a 7.5A fuse in the #19 slot, the "Radio Information Display" and downline Accessory Power Sockets WILL NOT energize! Replaced the fused and all is well. |
| All times are GMT -5. The time now is 07:48 AM. |
