-   -   2021 RDX Rear Wiper Blade size (https://www.acuraforums.com/forum/rdx-43/2021-rdx-rear-wiper-blade-size-8635/)
Greg516 Mar 18, 2025 05:07 PM
Does anyone know if there is a specific rear wiper blade for the 2021 RDX? I bought 12" Bosch conventional replacement blade, but it is too narrow and will not fit, the original blade frame is wider. Any information is appreciated.
Thanks,
Greg
John from PA Mar 19, 2025 12:00 PM
I don't generally buy the entire blade because the inserts/refills are significantly less cost. In addition many RDX models use the same wiper inserts as the Honda Pilot of the same year.
Front driver and passenger side refills. $14.60
https://acura.bernardiparts.com/Acur...p3js5RKd6drplo
Rear refill $7
https://acura.bernardiparts.com/Acur...TREAR-RDX.aspx
Greg516 Mar 19, 2025 04:10 PM
Hi,
thanks for the tip. I called the Acura parts department and they made the same suggestion. I picked it up from them and they were good enough to swap out rubber insert for me.
Thanks again,
Greg
