2021 RDX Rear Wiper Blade size
Old Mar 18, 2025 | 05:07 PM
Greg516's Avatar
Default 2021 RDX Rear Wiper Blade size
Does anyone know if there is a specific rear wiper blade for the 2021 RDX? I bought 12" Bosch conventional replacement blade, but it is too narrow and will not fit, the original blade frame is wider. Any information is appreciated.
Thanks,
Greg
Old Mar 19, 2025 | 12:00 PM
John from PA's Avatar
I don't generally buy the entire blade because the inserts/refills are significantly less cost. In addition many RDX models use the same wiper inserts as the Honda Pilot of the same year.
Front driver and passenger side refills. $14.60
https://acura.bernardiparts.com/Acur...p3js5RKd6drplo
Rear refill $7
https://acura.bernardiparts.com/Acur...TREAR-RDX.aspx
Old Mar 19, 2025 | 04:10 PM
Greg516's Avatar
Default RDX Rear Wiper Blade
Hi,
thanks for the tip. I called the Acura parts department and they made the same suggestion. I picked it up from them and they were good enough to swap out rubber insert for me.
Thanks again,
Greg
Soarer
Nov 26, 2023 11:24 AM
Bokes
Oct 10, 2023 03:54 PM
tano1967
May 29, 2023 11:32 AM
chico2021
Aug 6, 2022 03:30 PM
zpat4etsu
Jan 10, 2022 01:15 PM
