Need answer about changing wheels
I'm new to this forum but I figured this would be a good place to join since buying a 2007 TSX. I'm not a fan of the wheels that came stock and after one snow storm I discovered i definitely need new tires. I found a set I like on craigslist from a 2010 TL. Can anyone tell me if these will fit on the 2007 tsx. Can't pull the trigger until i know for sure.
What was the size of those tires you were looking at.?
WheelBrokerAng :) |
Do you have a link to the wheels in question?
I might , but you never gave me the size of tire answer , so I couldn;t respond...:)
I think you should tell us what is the size of your wheel tire, and it will be more efficent. By the way, if you are interested in I hope we can comunicate with each other, thanks.
i do not have it if needed i will purchase after that what should we do?
https://www.acuraforums.com/forum/an...t.php?f=10&a=1 |
did you purchase it lol?
What you have changed is the un-sprung weight which should make handling better,but not noticeably as you should not be pushing that hard on the streets.
When driving make sharp turns, if you have a bad wheel bearing it usually gets worse in a sharp turn to the bad side and will quit when turning to opposite side. Alot of times it is a bad allignment which can usually be checked for free at any tire dealer.
Well, they should fit, regardless. As long as you are stock height or not slammed.
