NSX Acura's Mid-Engine Combination of modern luxury molded into the shape of a high performance sports car...
help nsx problem
Old Feb 9, 2009 | 08:22 PM
diana71's Avatar
I have a '99 and the reception comes and goes in bursts at consistent
intervals, not as though it is a loose connection - from AM, FM, or CD
mode. Any thoughts? New radios expensive as is, I am sure, repair.
Old Feb 11, 2009 | 10:09 AM
i had a accord doing the same thing a few months ago.
all i did to fix the problem was unplug and replug the antenna wire back into the radio.
doing so scrubbed the corrosion off the plug and gave it a great connection again. some dialetric grease in there would insure it wont happen again.
do this first.
if it fixes it then we got lucky.
if not it only cost you 15-30 min and a little tube of grease.
Old Feb 12, 2009 | 10:49 AM
daniels_co's Avatar
this is very strange....
________________________
HD ready lcd tv
gua sha massage
Old Feb 15, 2009 | 12:32 PM
500hpNSX's Avatar
idk, wat that could be... check out nsxprime.. they might be able to help, i dont use mine bc i listen to the motor LOL
Pmarcus
Feb 24, 2015 04:11 PM
rnr568
Feb 12, 2008 11:40 PM
