Try the Digital Nitrous:)
:cool:Next Generation” in digital nitrous progressive controllers. The NX Maximizer uses state of the art circuitry to achieve a smooth application of nitrous power to the ground. With its, single box, compact design, limitless adjustability and rugged high amp capacity the Maximizer will handle all the solenoid amp load you can throw at it. The Maximizer is the only controller that allows your N2O system to deliver full power on the 100% setting.:)
I Did It
I took out your signature violations..Please post by the rules ...:cool:
That might a bit much for starters. Id try a multi stage kit and start with the lowerst setting.
Now that's better...Thank You !
Good Suggestion
1 Attachment(s)
Originally Posted by annothe09
(Post 10219)
I agree with this member-for starters go with his suggestion.. WheelBrokerAng :) |
| All times are GMT -5. The time now is 01:02 AM. |
