Onki Runnung Boards - best choice for your Acura MDX!
One of the simplest and most cost-effective ways to improve the function and looks of your SUV or truck is to bolt on a set of high quality Running Boards. Running boards are designed to provide extra grip and a platform for you to step in all conditions. Some running boards require drilling during the installation, while most will bolt into factory holes on your vehicle. They are generally available in two finishes: black or stainless steel.
One of the most reputable names in running boards production is Onki Corporation. Onki offers their running boards in a variety of lengths from 52 inches to 118 inches for a proper fit on all types of vehicles. So if you are looking for running boards for your MDX, you’ll find one that fits well and looks right. Here is the list of few options we have for the 2014 Acura MDX. Onki® - 72" Nerf Boards offer the traditional look of bright metal and black rubber along with the benefits of stainless steel and aluminum construction. Aluminum frame construction provides high strength and light weight. Onki® 328072 - Acura MDX 2014 72" Nerf Boards Onki® - 68" Volcano Running Boards - this running board’s 6.5-inch wide step framed by a 3-inch diameter steel for rigidity and strength. Hard rubber grip pads available in orange or black provide texture for secure footing, and can easily be replaced by lifting the removable top step panel. Onki® - Acura MDX 2014 68" Volcano Running Boards Onki® - 72" American Runner Running Boards offer the option of lighting for running board surfaces and the ground underneath that operates when any vehicle door is opened. Aluminum frame construction ensures corrosion-free strength, and a 1.5-inch steel tube available in either polished stainless steel or black mild steel surrounds the step area for rigidity. Onki® - Acura MDX 2014 72" American Runner Running Boards Once you and your passengers experience the convenience and safety these running boards provide, you’ll never want another car without them. Have you ever tried them on? |
| All times are GMT -5. The time now is 05:43 AM. |
