Engine Code PO498
Does any one know what this code "P0498 - Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit Low Voltage" means and how do I repair the problem? Thanks in advance!
I did a little research into the matter and found another thread talking about the same issue. Some of the replies suggested it could be a number of things. Maybe a faulty FTP sensor or it's just a part of the "check engine cap" warning. Not quite sure how to go about fixing it other than to have a tech run diagnostics on the sensors, maybe?
Here's the thread in question: http://www.ridgelineownersclub.com/f...ad.php?t=36128 Hope this helps a bit! |
