Door lock problem on 2006 MDX
Can you open the drivers side door from the inside (with the latch) with the doors locked? My wife has been telling me she has been doing it for years, but after a recent door problem, it no longer can be done.
If the doors are locked, you must use the switch or push up the button to be able to exit the car. Is this normal? Thanks! |
Originally Posted by njracer
(Post 12718)
If the doors are locked, you must use the switch or push up the button to be able to exit the car. Is this normal? is it the door lock switch? Thanks! |
[quote=njracer;12718]Can you open the drivers side door from the inside (with the latch) with the doors locked? My wife has been telling me she has been doing it for years, but after a recent door problem, it no longer can be done.
If the doors are locked, you must use the switch or push up the button to be |
| All times are GMT -5. The time now is 10:20 AM. |
