<div class="smallfont">
2001 MDX Transmission? <---Please HELP </div> <hr style="color: rgb(238, 238, 238);" size="1"> Thanks for looking. I have a 2001 Acura MDX with a trouble code P1750 The tranny seems to work sometimes, and sometimes it feels like its low on fluid (late to change inot gear or I have to ease up on the accelerator to allow it to change gear). Also when putting it into reverse it takes 3-4 seconds before it "pops" into gear. When I first start up it drives fine, but after a few miles these problems start happening. If I keep driving, the car gets really sluggish; as if I'm starting out of 2nd or 3rd gear, then one time finally the "A/T Temp" light went on. What could it be? I have tried looking up code P1750, and got mixed results: Either: 1) Low tranny fluid 2) Failed hydraulic control unit 3) Manufacturer Specific Powertrain Trouble Code 4) Mechanical problem in hydraulic control system of A/T clutch pressure control solenoid valves A & B, or problem in hydraulic control system (The last one seems most credible) Please help me, you can also email me at rome237@gmail.com |
eep well i hope this post isnt too late
1750 reffers to the pressure control solinoid that runs 2-3 gear shifts and needs replaced or the transmission needs replaced. |
