-   -   transmission question (https://www.acuraforums.com/forum/legend-23/transmissin-questin-3123/)
imfixinmopars Jan 9, 2009 02:10 PM
i just bought a 91 legend,and it has 85k miles,automatic.i have noticed the car wants to take off in 3rd?,and if manually shifted down into 1st,i think its taking off into 2nd,and if shifted into 3 or 4 it seem to go into 3rd. it always takes off in 3 if selector is in 3 or 4th.any ideas??? i really dont want to redo the trans.thanks,mike at imfixinmopars@hotmail.com
bezita Jan 22, 2009 09:04 PM
i think you must change the oil transmission. before you fill the new one you must empty the tank first. good luck[img]smileys/smiley10.gif[/img]
acuralegend Jan 24, 2009 10:04 PM
do you have a red flashing transmission light on the dash?
does the shifter position indicator show you in the current and correct gear?
it could be a bad shifter switch.
Also check all them silly fuses.hate to burn a tranny because of a 10 cent fuse
jujuM3 Feb 19, 2009 11:30 AM
well i had the same problem with mine but 4th didnt work on mine when i first got it. 1st did good so did second and 3rd. D4 kept blinking on mine and ud never go into 4th then 3rd finally went out to be honest with you diagnosis of my problem. new tranny 300 bones bro lol but now i have this new one it still has D4 blinking and sometimes the speedometer kicks on and off whenever it wants too
acuralegend Feb 20, 2009 10:32 AM
blinking D4 means there is a transmission code.
if your speedo is dropping out the the tranz comp is unable to see how fast you are going and may not give propper pressures to the clutches during a shift.
ignoring a blinking D4 will WILL burn that transmission up.
JUTYCUS Mar 4, 2009 04:30 AM
That's usually a problem with the VSS(vehicle speed sensor)
L3GDKANG/JDM-KA Mar 4, 2009 07:35 AM
[QUOTE=imfixinmopars]i just bought a 91 legend,and it has 85k miles,automatic.i have noticed the car wants to take off in 3rd?,and if manually shifted down into 1st,i think its taking off into 2nd,and if shifted into 3 or 4 it seem to go into 3rd. it always takes off in 3 if selector is in 3 or 4th.any ideas??? i really dont want to redo the trans.thanks,mike at imfixinmopars@hotmail.com[/QUOTE]
i'd say check your fliud you many need to have your trans flushed as the old fliud could be burnt. Ive flushed my trans on all 5 of my legends and i seems to make them last longer. im also ASE certified.Edited by: L3GDKANG/JDM-KA
maraco Mar 18, 2009 12:42 PM
I have a 91 legend and had the same prob. Changed the VSS and it works like new. smooth shifting.
