transmission question
Old Jan 9, 2009 | 02:10 PM
imfixinmopars's Avatar
i just bought a 91 legend,and it has 85k miles,automatic.i have noticed the car wants to take off in 3rd?,and if manually shifted down into 1st,i think its taking off into 2nd,and if shifted into 3 or 4 it seem to go into 3rd. it always takes off in 3 if selector is in 3 or 4th.any ideas??? i really dont want to redo the trans.thanks,mike at imfixinmopars@hotmail.com
Old Jan 22, 2009 | 09:04 PM
bezita's Avatar
i think you must change the oil transmission. before you fill the new one you must empty the tank first. good luck[img]smileys/smiley10.gif[/img]
Old Jan 24, 2009 | 10:04 PM
do you have a red flashing transmission light on the dash?
does the shifter position indicator show you in the current and correct gear?
it could be a bad shifter switch.
Also check all them silly fuses.hate to burn a tranny because of a 10 cent fuse
Old Feb 19, 2009 | 11:30 AM
jujuM3's Avatar
well i had the same problem with mine but 4th didnt work on mine when i first got it. 1st did good so did second and 3rd. D4 kept blinking on mine and ud never go into 4th then 3rd finally went out to be honest with you diagnosis of my problem. new tranny 300 bones bro lol but now i have this new one it still has D4 blinking and sometimes the speedometer kicks on and off whenever it wants too
Old Feb 20, 2009 | 10:32 AM
blinking D4 means there is a transmission code.
if your speedo is dropping out the the tranz comp is unable to see how fast you are going and may not give propper pressures to the clutches during a shift.
ignoring a blinking D4 will WILL burn that transmission up.
Old Mar 4, 2009 | 04:30 AM
JUTYCUS's Avatar
That's usually a problem with the VSS(vehicle speed sensor)
Old Mar 4, 2009 | 07:35 AM
L3GDKANG/JDM-KA's Avatar
[QUOTE=imfixinmopars]i just bought a 91 legend,and it has 85k miles,automatic.i have noticed the car wants to take off in 3rd?,and if manually shifted down into 1st,i think its taking off into 2nd,and if shifted into 3 or 4 it seem to go into 3rd. it always takes off in 3 if selector is in 3 or 4th.any ideas??? i really dont want to redo the trans.thanks,mike at imfixinmopars@hotmail.com[/QUOTE]
i'd say check your fliud you many need to have your trans flushed as the old fliud could be burnt. Ive flushed my trans on all 5 of my legends and i seems to make them last longer. im also ASE certified.Edited by: L3GDKANG/JDM-KA
Old Mar 18, 2009 | 12:42 PM
maraco's Avatar
I have a 91 legend and had the same prob. Changed the VSS and it works like new. smooth shifting.
snajim
Nov 28, 2008 10:08 PM
rsxracer
Sep 26, 2008 09:01 PM
19998integrags
Jan 23, 2007 09:24 PM
kfischer
Nov 10, 2006 08:19 PM
Jan 31, 2005 02:46 AM
