< src="http://www.google-analytics.com/urchin.js" =text/> </> How do I get my stock steering wheel out without setting off the airbag, do I need a special tool from the dealership? Has anyone changed the stock wheel in the legend and if you did do you know where to find acheep hub adaptor? < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
< src="http://www.google-analytics.com/urchin.js" =text/> </> I figured it out after an hour or two on the phone. If anyone wants to put in a new wheel there are 5 6x16 torque bolts to get the air bag out and nobody makes a hub adapter for a legend. My steering wheel is a momo and I foundout that the nsx wheel is exactly the same as the legend so a kit for the nsx will work for the legend and momo makes one and it was only $69 insted of $129 for a sparco weld on which would also be acouple hundred dollars more to install. So this should save a few hundred if anyone wants to do this. < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
