-   -   Problem with headlight (https://www.acuraforums.com/forum/legend-23/problem-headlight-3058/)
bbsitum Dec 20, 2008 01:09 AM
<DIV>I have Acura Legend LS coupe year 90. When I torn headlight on low beams (all 4) don't work, but high beams work. Before for years it was problem with dim low beams and before 2 weeks all four went out. Problem is not in lamps as I replace one to be sure and I have same problem at one brand new. Light relay work well same like, dimmer relay, they open and close(I replaced both to be sure - same problem exist). Light switch close light relay - it mean it work to. When I removed light relay and set voltmeter lead instead it show 12V when I turn light switch on - how should be. Is it someone know what is problem. It confuse me because wiring diagram show that all for light have different line from lighting relay to 2 different ground.</DIV>
<DIV>I have problem with condenser (AC) fan too because it don't work when I turn on AC (or little work and a lot don't) but always work over night when car sit in parking lot. This second problem is not so urgent but any idea would be helpful</DIV>
