Please help legend wont start
Old Jul 5, 2009 | 03:57 PM
acuraman1994's Avatar
Default Please help legend wont start
I am new to the forum and was looking for help
I have a 1994 legend LS coupe with 225,000 mile on it
The car has been great til 2 days ago. I went home for lunch one day and the car drove fine. I went to start it up to go back to work it started and ran for about 2 seconds and then shut off. it turns over and sounds like it wants to start but it wont. I just had a tune up and new fuel filter done last month
Does anyone have an idea what the problem could be or where I should looking first start. also I am replacing the motor soon with a jdm motor and want to know if anyone else has done the same and have they have had any problems it the motor and where is a good place to order the motor from
thanks
Old Jul 7, 2009 | 08:23 AM
L3GDKANG/JDM-KA's Avatar
it may be your main relay its under the dash on the drivers side it will need to be replaced or resoldered. I have a club member who replaced his motor with jdm motor and has han no problems as of yet and its going on 2 years and he drives the car everyday. you will have to use your usdm injectors.
Old Jul 8, 2009 | 02:38 PM
I replaced the main relay today but the car still wont start. if i turn the motor for about five seconds i start to small gas so i know the fuel pump is working i checked the timing belt and it turns when Im trying to start the car any other suggestions
Old Jul 8, 2009 | 05:43 PM
rsxsblue_1's Avatar
did you check to see if its getting fire. if not do a compression check. got a 90 acura integra did the same thing. shot starting fluid up intake started right up and ran, try fuel regulator also.
Old Jul 9, 2009 | 09:16 AM
your injectors are leaking replace the o rings. check the filter on the fir wall as well.
Old Jul 10, 2009 | 07:09 PM
thanks for all your help guys
I had my towed to the shop yesterday and got it back today it was the fuel pump
I guess I cant say much it was the original pump
DaddyDawg
Oct 17, 2012 10:15 AM
Hacsta
Oct 11, 2012 11:14 AM
Rsxdc5
Apr 25, 2012 09:21 AM
bxclip
Jan 9, 2011 02:45 AM
gizmoDBJ
Sep 20, 2006 10:37 PM
