Hi, I have a 1992 Acura Legend and I' am facing following problems
1. The volume control on the steering wheel is not working. 2. The Trunk release switch just quit working, if it is the fuse then can you tell where should I look for the fuse. 3. Although it happens very rarely but sometimes when I start driving the car in the morning and press the brake pedal for the first time it makes a griding noise and the brake go loose but after driving 100 yards it comes back to normal</span></font> |
you have a fuse box by your driver's door under the dash and one under the hood! you may have corrision on your plug for the trunk switch! you may have a air in your brake lines. |
1. The volume control on the steering wheel is not working. 2. The Trunk release switch just quit working, if it is the fuse then can you tell where should I look for the fuse. 3. Although it happens very rarely but sometimes when I start driving the car in the morning and press the brake pedal for the first time it makes a griding noise and the brake go loose but after driving 100 yards it comes back to normal |
| All times are GMT -5. The time now is 09:33 AM. |
