Ok heres my situation my 1994 acura legend gs stalls when idoling. I mean the engine turns nomally then revs normally when key is turned then instead of dropping to a normal idol it falls below 1 rpm sounds like its clogged and half way powered then emits white smoke from exhaust and under engine then cuts off suddenly. I have taken it to miami acura and after 1200 dollars they have taken from me the car still doesnt work and the "certified experts" cant figure out the problem after a month in the freakin place somebody please help me! Im a student at the university of miami and need someones help to fix this car being that it is my only source of transportation again hope someone can help.< src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-41"; urchinTracker(); </>< src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-41"; urchinTracker(); </> < src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-41"; urchinTracker(); </>Edited by: Gladiator90 |
have they checked your coolant level?
there is a idle up controll valve that requires coolant to go throught it so it knows where to set your idle. |
< src="http://www.google-analytics.com/urchin.js" =text/> </> well i checked it today and even added a little and it seemed ok but the coolent reserve tank doesnt have anything in it. hope that helps where is the idle control valve? < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
if you haven't solved the problem yet look at my posting "wierd problem" I had sevral people look at my car and no one knew what the problem was it took me a month to figure out it was my MAP sensor and my car did the same thing pretty much.
