alright guys im having a problem with my 94 acura legend..in the morning its really hard to start probably have to let it turn over for a total of 20 seconds. pretty much anytime the car is cool its super hard to start. also it will die after i start moving(low rpms)just after i start her up.but it only does this randomly. but once its dies its really hard to start agian..HELP!!!
i would have the main buss relay checked.
if thats ok have a fuel pressure test performed. if that is ok. engine computer test. some times a bad ignition switch can do what you have described. |
mines the same way man i still can't figure it out is there anyone on here who has had this problem and fixed it already
Main relay the wires are about to brake on the inside you can take it appart and replace the regulator by soldering it in you should be able to pick them up at any radio shack or any place like that! i've done it 2 3 of my 5 legends.
i used the lucas fuel injection cleaner on my car last ant drove for about 100 miles and mine started right up this morning i was amazed and shocked
i saved a set of injecters on my prelude with some bg fuel additives. the stuff does work.
okoutlaw, good suggestion from acuralegend's post 12/15, following yours. I had the very same problem, had ignition switch replaced 12/16, lol. $190 bucks.
| All times are GMT -5. The time now is 04:11 AM. |
