-   -   HELP PLZ (https://www.acuraforums.com/forum/legend-23/help-plz-2969/)
deathfromabu Nov 9, 2008 06:07 PM
hello all new here just bought a 1991 legend ls. it has sum major issues. ok itll start and run fine. smoothest car i ever owned. but when u get down the road in it about 10 to 15 minits it starts loosing fuel or sumthing. like its got a miss. but if u take ur foot off the gas itll run just fine. also if u let it continue to miss and carry on itll get worse. and eventually all the lights start dimming with the miss in the motor. and if its missing and u floor it the motor just droppes in rpm till it gets to about 500rpm and the itll start coughing sort of. then if u put it in park with it missing and try to rev it up it continues to miss. ruled out the tranny and mass air flow sensor. also has a very very minor injector leak. its damp wen u start it up then after 2 minits its dry. not even a drop of gas comes out. plz help love this car owned one before and loved it.
acuralegend Dec 15, 2008 01:58 PM
is your alternator ok?over volting???does it start ok after this happens?like the batt is dead?
have you checked the tuneup parts?cap/rotor/plugs/ wires.
a plugged fuel filter can give you simular results.
bezita Jan 22, 2009 09:13 PM
you must check the batteryand and fuel pipe. maybe your muffler has problem. i think you must service your car. good luck.[img]smileys/smiley10.gif[/img]
sorry if not helping [img]smileys/smiley6.gif[/img]
