Anyone know what other OEM rims will be compatible on my 93 legend? Will the center hub be a concern even though the bolt patterns are the same? Any suggestions would help.
exact fit on the hub center DOES MATTER with out it the rim may shift causing a ballance issue
thanks.....any idea what the offset is? and are there other oem rims with the same fit? is boring the center recommended?
eep. boring out the rim is NOT recommendedyou may remove structure that will keep that wheel from breaking.
tirerack.com i think has rim offset info. and they my have hub sizes as well |
| All times are GMT -5. The time now is 04:09 AM. |
