93: what is this fuse designation?
What is this fuse designation?
In the engine compartment fuse box there is a 20 Amp fuse which is labeled
Bose
(H/L washer)
I don't have headlight washers. Were they an option on the '93? I am trying to trace a battery drain and it may be related to this circuit (including a relay mounted just behind the top of the radiator [drivers's side]).
Bose
(H/L washer)
Thanks for responding. I will be home tonight and post the info. I will try to take a photo of the inside of the fuse box cover to see if that can help you.
So far the battery drain seems to have slowed significantly by removing the fuse. When I came back from a "charging run" after jumping the battery yesterday, the voltage read 12.49 and then settled down to 12.36 during the day. This AM it was 12.30, and I will test it again tonight.
Please check tonight (I am on PST).
Ken K
Ken K
OK, here is the info:
JH4KA7.......
When I checked the voltage at luhch, it was only .01 less at 12.29
If you have any idea where the amplifier is located, I would appreciate the info. Any idea what else might be on the circuit? Also, is any of this info online? Or is it worth purchasing a manual like Chilton's?
Here are the fuse box cover photos:
</font></font>
Edited by: kdkrone
ok found it. and thanks for the sweet pic.
ok there is a recall on the bose amplifier.
even if your out of warantee you may still be elidgable for the acura goodwill compensation.
acura bulletin # 94-015
