[img]smileys/smiley11.gif[/img] Everytime I turn on the heat above 70 degrees a smell of burning plastic comes through the vents for about 30 seconds and after that it is no longer there. Does anyone have any clue what that would be? Jesse Edited by: jesserb306 |
IM not sure if you have the same problem i had but it might be. every time i turned on the heat i would smell the burning plastic and so i looked around and found that the wiring for the heater was loose and caused the plastic clips to burn. might want to check it out
steve |
| All times are GMT -5. The time now is 05:22 AM. |
