91 legend 3.2 problems
I recently acquired this car, it's kicking a code. I've read about the LEDs on the ECU. But for some reason, mine doesn't have them. When I jump the ALDL the check engine light comes on solid and that's it. Can some one tell me of another way to scan the ECU?
ya i agree that there are some problems like
ABS system failed at approximately 75,000 miles. Brake system Master cylinder failed twice. Air conditioning intermittently blows warm; dealer could not fix until I found an Acura Technical Service Bulletin (TSB) identifying the problem as a cracked circuit board under front passenger seat. Driver window slowed to crawl, replaced once; now doing it again. Door lock system buggy; will lock your keys inside with engine running. Driver seat leather split on left bolster. Transmission mounts failed twice and had to be replaced. Motor mounts failed and had to be replaced. Radiator failed at 115,000 miles. |
