Hi, Thanks for this forum
I have a 88 acura legend 6cyl 5spd and we need to get it home as soon as possible from the roadside, however it has a known clutch fluid leak and we need to get some pedal travel just to get it home but I cannot locate the bleeder valve to quickly bleed the system, Can someone direct me to the bleeders location please, Thanks Big Time In Advance Signed.....Got to get car home ASAP</font> |
between the radiator and the engine close to the centerline of the engine bay.
low in height i would say about 8-12 inches lower than the valve cover. 8mm wrench should be to the driver side of the front motor mount. |
Thank You acuralegend We'll Drive Out And See If We Cant Get It Back Home</span></font>
