I recently had the engine rebuilt in my 95 Legend. I am getting alot of blow by. There is actually oil in the tail pipe. It uses about 1 qt of oil for every 250 miles driven. Yesterday, I shut the car off, tried to start it again 5 minutes later. It cranks but won't turn over. It tried a few times but noting. Not sure if it is related to the rebuild or not. I checked the fuses for fuel pump ect. , which were fine. Help.
Sounds like the rings havent seated yet or will not be seating.
OR the valve guildes are not working or maybe something is missing and a huge oil leak like that can foul spark plugs to the point they will no longer fire. i would recommend taking the vehicle back to the guys you got the rebuild done at and have them look it over. if they give you any greif stop on the spot and take you car some where else. but get it looked at befor you ruin the exhaust or oxygen sensors. |
