Check engine ; 7 flashes
Old 03-24-2013, 09:36 PM
denism28's Avatar
Default Check engine ; 7 flashes
It is the throttle position sensor. The light goes on only when warm. Could it be soldering problems like the starting relay over the steering tube ???
Old 03-25-2013, 01:47 AM
Talking Hi Member
You need to put in the year,make,model and trans and engine size for more information..Engine ..what litre?
Old 03-26-2013, 07:41 PM
denism28's Avatar
Default Legend 7 flashes
Sorry; It is a Acura Legend 1990 2.7 LS sedan automatic V6 with 100000 mi . The car runs perfect even if the check engine is on .. which happens only when the motor is hot ; if the light didn't show, you would'nt know that there is a problem. The replacement part comes complete with the air v olume sensor and costs 700$ As the trouble happens only when the motor is hot I suspect a soldering problem like the main starting relay over the steering tube. I really appreciate any suggestion youy can give me. Thanks.
mattrich0988
08-28-2007 07:41 AM
priority04
06-13-2007 11:52 AM
Spiez
11-08-2006 01:09 PM
GS-R_JHULL
09-03-2006 06:45 PM
gsrgirl
03-14-2005 05:22 PM
Quick Reply: Check engine ; 7 flashes
