-   Interior (https://www.acuraforums.com/forum/interior-24/)
-   -   91 Acura Integra GS (https://www.acuraforums.com/forum/interior-24/91-acura-integra-gs-1245/)
vb0117 Jun 16, 2007 02:53 PM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I have two concerns regarding my acura. First of all, the antenna just stopped coming up when you turn the radio on. Is there a way of checking this or do I need to buy a new unit?
My second problem is when it is really cold outside (winter time) the car will not pull out of park. It takes forever to get the thing in reverse or drive. I have let it run 45 minutes waiting to get it out of park. Any suggestions? I took it in for diagnostics and they couldn't find anything...
smithy Aug 27, 2007 08:22 PM
regarding problem number one
do you hear any sounds on the antenna when you turn on the radio? if yes then your antenna is working but its stuck or something
vb0117 Aug 29, 2007 10:00 AM
There is no sound from the antenna at all.
acuralegend Aug 29, 2007 11:05 PM
those thing go bad all the time. bit the bullet and replace the assembly.
i have had bad luck with just replacing the mast.
but its always a good idea to check fuses and such.
#2 there is a aluminum cover over your shifter cable and linkage on the
bottom side of the tranz. check to see if its there maybe reseal
it so water cant get in and freeze. and no more parking
under water.
