Hey I was just wondering. I am about to buy wheels and tires for my integra. The rim sizes all match up with mine EXCEPT the Center Bore is 57.1 and my integra is 56.1. What do I have to do in order for them to fit? anything?
My guess is that the center bore is larger on the aftermarket rim to make sure that there are no fitment issues. Your rims support the weight of the car on the wheel studs so an aditional .5 mm on the inside circumference won't matter. there won't be any slop as long as the lugnuts are torqued down properly. make sure you check your wheel offsets so you don't get tire rub.
| All times are GMT -5. The time now is 07:24 AM. |
