-   -   Use Viagra after Bar's head gasket badly failed (https://www.acuraforums.com/forum/integra-22/use-viagra-after-bars-head-gasket-badly-failed-6693/)
ikemitune Aug 12, 2013 12:53 AM
My 1997 Acura Integra heavily punched for using Bar’s head gasket fix
TWO THUMBS DOWN FOR BAR’S HEAD GASKET, A REALLY PIECE OF JUNK!
!997 Acura Integra, with only 100,000 miles on it and previously owned by my mom
It is disgusting that you used a product to fix a small leak and you ended up having heavy damages on it
All imaginable damages, including water pump, heater core, thermostat and radiator and then follow engine for overheating it
Bar’s clogged everything, perhaps your whole house if you let the product to get in there
Someone told me, perhaps Bar’s is being used by plumbers to clog everything and coming after that to make big money in repairs
The small leak, turned into a nightmare, even when I followed all the instructions
After driving only 50 blocks and done many stops for overheating, the car finally quits and the next day much worse
$1,175 for parts and the overheated engine has to be replaced by a new one. New engine $6,525
What kind of junk is this Bar’s product?
ikemitune Aug 14, 2013 02:07 AM
It's regarding to Bar's and its bad products
I borrowed other people experiences on Bar's head gasket fix, because I feel terrible bad and I'm keep doing some investigation on Bar's Products
Bar’ Head Gasket Fix # 1111 product used and reported by a mechanic
Its kinda a PITA (pain in the ****, a major annoyance) sometimes though when you actually go to do the head gasket later on. The stuff kind of "welds" itself between the gasket and the block and head. One time we had an old FJ (Toyota) that we were trying to do a HG on, and obviously someone used some sealer on it before. We had everything undone, and had a cherry picker hooked to it pulling up. We kept thinking we forgot a bolt or something, and as we were poking around in there the head just totally popped off. Just about hit me in the head haha. Cleaning all the sh** off it was the biggest PITA ever haha. I had to hammer and chisel it off carefully, and even then didn’t get it all. We just ended up taking it to a machine shop and they got the rest off somehow. Just letting you know. Also, it doesn’t always work. We had a lot of cars come in with blown HG's (mostly Subaru’s), and it worked on like 1 out of 6 or 7, and it only lasted a little while. It is definitely not a permanent fix.
AJ, AVON, IN
"Used it exactly as instructed on my 98 Subaru Legacy. It did nothing to correct the overheating problem, but it did noticeably clog the heater core. For the money, it seemed like a reasonable thing to try to get a month or two of normal driving before I come up with the money for repair. The first thing I noticed when I got into the car was that heater was blowing cold air. The car overheated some 5 minutes into my trip. As I was pulling over to let it cool, the upper radiator hose blew off. I had some coolant in the car, so I refilled and tightened the radiator hose. Let the car cool for a bit, then turned around to go back, and the upper rad hose blew off again. The radiator cap was new from the dealer, so couldn't have been that. Definitely would NOT recommend this product, as my car was ok to drive short distances before I used it. Now I can't even drive it to the repair
BjK Texas
Bar’s Head Gasket product is definitely the cause, after using the product, the vehicle went from being drivable on runs up to 30 minutes, to overheating after driving just 2 or 3 miles across town... almost instantly .now, regardless of the product, the overheating problem had been getting progressively worse over time. In the winter it was a non-issue, but as the weather warmed up, it became an issue again. The problem was first prevalent in fall of '09, at which time i could drive the vehicle for an hour or more before overheating. This spring, prior to using this product, drive time had diminished to about 30 minutes. Immediately after using this product, drive time plummeted to just a few minutes."
Vic
Greene County Tennessee
Casual driver
"Based on the reviews I gave it a shot. It appeared that it may work. When I put it in the radiator and followed the directions on the bottle, the steam almost stopped coming out of the tailpipe. I let the car sit a full two days before I took it on the road. Within five miles it was blowing water out the tailpipe and the temperature started rapidly going up. Waste of my time and effort. The product does not work as they try to claim. I am now convinced when you have a head gasket problem there is only one real cure, REPLACE THE GASKET and forget the miracle cures."
The issue is not that you can't expect much from a product like Bar's
Bar's Products rips off customers and duped them by thousands and thousands, telling them that Bar's is a permanent fix
We have Consumers Protection Laws and the Government Agency must put a stop on all that
A car is not a toy, products like Bar's do a lot of damages to car engines
Do you think the people have to foot the bill and shut up?
Bar’s Products owners are corrupted people and swindlers, having thousands of complaints on the product that damaged engines and all cooling parts
Bar's head gasket do not work on aluminum heads. Used to work on very old engines with iron heads and iron blocks
Bar’s never paid a dime on claims. Bar’s keeps begging to people in the internet to buy its products, but this old product should be kicked out from all shelves
Bar’s owners are living in the state of Michigan, where even the rats are getting the heck out
The best Bar’s owners can do, is to go to a retirement home and spend the rest of their lives in there, if they can get away from lawsuits.
Bar’s Products owners, allergically avoid contact with people, thinking that the car repo-man may come to take their cars for no making the car payments
Bar’s president, Robert J Mermuys lives a primitive life no having clean water in his house.
Fenton Water and Power Company do not provide any water to Robert J Mermuys house
Robert J Mermuys house is having a septic tank
(where went all the fakes and bogus millions of bottles sold?
THESE FAKERS NEEDS URGENT A BRAIN SURGERY!.
IT'S VERY HARD TO MAKE A LIVING SELLING A FEW BOTTLES OF WHATEVER ON THE NET
Robert J Mermuys applied for a permit to drill a water well, but it was denied.
Perhaps the Fenton Water and Power Company got the gut feeling that those swindlers will bottle waste water and resell in the market as PERRIER WATER!
ONCE A CROOK, ALWAYS A CROOK!
Bar's scammed people, but they are not going to scam people no more
