type r door swap
have an issue with the elecrical on my jdm doors. swapped all the harnesses and swiches from my oem doors to the jdm doors. i can only get the drivers window to work. Miirrors on both side dont work and the passenger window will not or from either switch. Checked for breaks in the wire and found none. jumped the window motor and it works fine. can anyone give me a hint.
i have solved everything but the mirror issue. I had a bad ground on the passenger door. i had to clean up the hinge and the mounting location on the new door and remount. I am going to do the same in hope it will solve the issue with the power mirrors.
I don't think it will solve your problem.
