hey there, i'm new to the forums so excuse me if i post this in the wrong section. I have purchased some new altezza style lights for my 94 integra. here's a link to them http://cgi.ebay.com/ebaymotors/94-01...EGRA-2DR-SMOKE -LED-ALTEZZA-TAIL-LIGHTS_W0QQcmdZViewItemQQcategoryZ33716QQi hZ010QQitemZ200110573302QQrdZ1 a problem i have run into to is this. the led's have their own connector, an orange and a black wire. i believe that they are supposed to be my running lights but the original connection has a green, red and a black wire. The stupid box didn't come with installation instructions so i'm a tiny bit lost. i'm thinking that the red (original) and orange (led) wires should be spliced together. I don't want to start messing with it a screw something up thou. any help would be appreciated. |
I would contact the seller and ask him for a wiring document from the company. Let us know what he does for you about it! WheelBrokerAng [img]smileys/smiley14.gif[/img] |
It took me a minute of thinking, but i figured it out. there are 4 light connections in the original setup. i had to remove one, the side running light and splice in the LED. that took care of the problem. sometimes it just pays to reconsider the problem :) |
Originally Posted by narus
It took me a minute of thinking, but i figured it out. there are 4 light connections in the original setup. i had to remove one, the side running light and splice in the LED. that took care of the problem. sometimes it just pays to reconsider the problem :) [img]smileys/smiley2.gif[/img]ah yes , the mind is a wonderful object..good job sir! [img]smileys/smiley16.gif[/img]Edited by: WheelBrokerAng |
Just hook them all together and hit the pedal....
As a side note to this project, remove power via the negative battery cable or you will blow your fuse when you splice! HID headlights are a GREAT upgrade. They really lightup the road [img]smileys/smiley1.gif[/img] |
And yes, do as AkinDen recommends you do 1st, must disconnect the Negative battery cable always when working on your car...except when trying to find shorted wiring....I Think [img]smileys/smiley17.gif[/img] WheelBrokerAng [img]smileys/smiley16.gif[/img] |
