Hi. So i have a 91 tegi with a b20z and a jdm s1 tranny. as you know the S1 is really short geared so at 70 in 5th im at like 4500. I was wondering if i switch to an LS tranny how much "pep" would i lose and if my top speed right now is 110 what would it approximatly jump to??? oh and i have a type R flywheel. Thanks. |
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> ok, some of the best honda trannys are as follows, YS1-cable tranny from 1st gen GSR S80-hyraulic tranny from type r integra S21-hydraulic tranny from 99-00 Civic Si all of these trannys have great gear ratios and will bolt up to your motor. hydraulic trannys will require some work since your current setup should be a cable tranny. as for speed and pep variations, all of these should help you to get up to more like 130-145 mph. |
Thanks man, Ill let you know what happens |
| All times are GMT -5. The time now is 07:24 AM. |
