I drive a 99 Integra GS and lately have noticed that the steering wheel squeaks whenever I turn the wheel nearly all the way(mostly squeaks during parallel parking and sharp low speed turns).Had light maintence done on it roughly 5K ago, shouldn't inspection and lube been a part of that?If not what areas do I need to lube and is this a do it yourself job? Recommended lube? Other suggestions? Thanks!
I'd start with checking the power steering fluid and pump... make sure there aren't any bubbles in the system... there are other things that you COULD do... but really, those would just be peace of mind things... like GAA on the lube points and stuff like that... GAA = grease... it's more than likely the power steering
