Hello... I recently purchased my first Import a 94 Integra RS... I'm currently looking to do an engine swap and was told that a 240 sx Turbo would fit just fine and give me the most bang for my buck... I'm wondering (being brand new) if this information is correct.... Would it fit and give me the most for the least lol?... THanks for the help! JLEdited by: jlwest82 |
who told you that?? if you wanted a silvia motor in your car you probably would have bought a 240sx, am i right? if you want a faster motor that is farily cheap you should look into a b16 motor out of an sir or sirII which you can find on www.inlinefour.com or if you want to spend a little bit more and get a little bit more power go for the b18c out of a 95 gsr.the b18c would be great for your car seeing as how it's already OBDI and if you're interesting in top speed with some minimal bolt ons you could do all of 150. either way you're gonna be a whole lot happier after getting rid of that non-vtec motor and that transmission whose gears could use drastic improvement. < => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
