< src="http://www.google-analytics.com/urchin.js" =text/> </>I just bought a 1992 acura integra ls , and the only thing wrong with it is that the passenger window CAN roll down, but CANT roll up. any body know what the promblem is???????? i took apart the door panal and check all wires and check the swith, but i cant seem to find anything wrong.... again the window rolls DOWN but not UP. i tried pulling the window up by hand, but it wont move. All wires are connected and the switch is good in order for the window to roll down but it just wont roll up... the drivers door cant even roll the passenger window up. all fuses are good..... whats the promblem????????help me.... < =text/> _uacct = "UA-939292-41"; urchinTracker(); </>< src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-41"; urchinTracker(); </> < src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-41"; urchinTracker(); </>Edited by: tegra2009 |
< src="http://www.google-analytics.com/urchin.js" =text/> </> my window did the same thing. on the bottom of the window there are two nubs that slide in the track, check that. all they do is screw in. on mine the nub was loose so it binded against the track and wouldnt move. < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
also check the driver side window switch.
it runs both or all 4 windows and i have seen them go bad and only let windows go down and not up. till you get it fixed you can hot wire the window up after the door panel has been revoved then pull that winows fuse so it wont go up or down. im betting your going to replace the drivers side window switch assembly. < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41"; urchinTracker(); </> |
