-   -   need some info (https://www.acuraforums.com/forum/integra-22/need-some-info-1882/)
MIKE07 Dec 10, 2007 11:42 PM
i have a 96 acura integra 4dr and notice that i pump gas way too much car runs fine but im pumping gas almost everyother day and i dont drive far at all. can it be a fuel filter?
b18c1acuraguy Dec 11, 2007 09:10 AM
you should def check the fuel pump but i would also do a full tune up by changing plugs, wired, dist cap and rotor... along with the air filter and fuel pump they all very simple and affordable should take you about 30 minutes to do all .... also change the oil and run a bottle of fuel injector cleaner through a full tank of gas, if your injectors are clogged you will be killing ur milage.... hope this helps < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
MIKE07 Dec 12, 2007 03:22 AM
alright cool thanks for the help really needed it
