need help to start build for 300+hp
Old Jul 30, 2008 | 02:37 PM
shaynem's Avatar
this is my first car that i wanna fix up and i dont know what to to or where to start how do i get 300+hp in a b18b motor then add a turbo plz. start the build Edited by: shaynem
Old Aug 2, 2008 | 02:05 AM
OneHandHigh's Avatar
First off, to make 300 hp usable on a teg you definitely want a limited slip differential and possiblya diff tranny. (alot of integra builders prefer the Gs-r tranny over the Type-R tranny.)
As far asjust making 300 hp,although ur b18b doesnt have vtec ithas a lower compression and responds better to turbo than a vtec motor. If your limited on funds start with the basics, intake(short-ram or cold-air with a good K&N filter), andexhaust.(end up with full exhaust, turbo header manifoldfollowed by 2.5 - 3 inch piping to the tailpipe)
Other than that upgrade your ecu, distributor, good NGK spark plugs, throttle body, fuel rail, injectors....im tired so i might have left out a few things but thats basically it,you may not NEED some of these but it's worth it.
Lastly, the MOST important part of an engine build is to have it dyno-tuned. In some areas of an engine build people sometimes cut corners or try to find cheap options, but when it comes to getting it dyno-tuned its worth every penny to take it to a badass shop.
For 300 hp you dont HAVE to do theinternals of your motor,and if you dont,dontpush more than8 psi. Also, unless you do internals you will prob want most everythingI listed to make 300 hp.
FYI: This is just general information from an integra nut, i'm not a professional though, so make sure you research before you do anything. Good Luck.
supremeryan
Sep 5, 2011 08:00 PM
CTBob
Jan 31, 2010 01:20 AM
xsdudztx
Jul 26, 2007 12:32 AM
xsdudztx
Jul 15, 2007 03:47 PM
00teggy09
Dec 13, 2006 11:45 AM
