Okay here i go. I have a 95 Integra. I dont know alot about these cars i need
help. I start the car up and let it run for a lil bit. it doesnt seem to build up any pressure in the radiator or any of the hose. The temp gauge says it takes the car forever to warm up and the heat sucks. i would say the thermostat but i would rather ask people that know about these cars. thanks bill |
if the thermostat is stuck in a open position then it will take forever to heat up if at all and your heater will suck.
have that replaced and then have a pressure test performed on the system to check for leaks. do your self a favor buy a dealer thermostat or a (oem) thermostat. the aftermarket ones like you would get from a parts wearhouse tend to suck. and warp fast. < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41"; urchinTracker(); </> |
| All times are GMT -5. The time now is 02:06 AM. |
