-   -   engine SWAPS!!!!!!!!!!!!!!!!!!!!!!! (https://www.acuraforums.com/forum/integra-22/engine-swaps-503/)
96_integra_GSR Jul 29, 2006 05:58 PM
I am new to the forum but i just had a few questions. I just bought a 96 integra gsr and it has crazy miles on it, and I want to do a engine swap to the car. What engine do you think i should go with? and you can fit a b18c-R G1 v-tech engine in the GSR without any problems or alot of extra work correct!
aremkaesteg Aug 4, 2006 02:04 AM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
all right, your question is valid and has a simple answer. dropping in a type r motor wouldnt be that hard, however, type r motors arent cheap, especially for a full swap. my advise to you would be to spend probably half the money you would for a b18c5 and just pay to rebuild your current setup and add some performance parts while doing so. depending on where you go and what you add you should be able to save at least 2-3 K which would be better spent somewhere else on the car, like some rims, tires, and brakes. although if you're h*ll bent on buying a type r motor go to www.inlinefour.com and you can get quality parts and fast reliable shipping.
