I have a 1994 acura integra with the b18 and im putting it in a 1993 honda civic ex. Is there going to be anything that im going to have to swap or will it slide right in? |
you are going to need some new motor mounts (hasport) the wiring harness from the b18 and possibly a shift linkage from a del sol si. also you may or may not need to find an applicable throttle cable that will work with your new setup. < => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
YOU WILL ALSO NEED TO USE THE T BAR ON THE BACK OF THE INTEGRA TRANS, AND USE INTEGRA MOTOR MOUNTS
| All times are GMT -5. The time now is 03:57 AM. |
