engine swap
you are going to need some new motor mounts (hasport) the wiring harness from the b18 and possibly a shift linkage from a del sol si. also you may or may not need to find an applicable throttle cable that will work with your new setup.
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
