So...i got a problem with my engine.... its leaking from the right side kind of by the pulley system.... i jacked up the car and couldn't find the leak so I'm not sure whether its something in the block or loose connection or something.... i do know that the higher i rev the, the more it burns. Any suggestions or answers would be appreciated :)
front seal. water pump. powersteering hose
what is it leaking? oil? red or black??? |
I would think if its oil then its your main seal if its coming out buy the pully then it is def your main seal and an easy fix with the right tools and a little time you should not have to pull the motor but you will have to retime the car when your done if you dont have any experiance doing this it is a good idea to get some one who does if it isnt timed correctly you can do catastrophic damage to your motor
1 Attachment(s)
2 things there i believe. the valve cover above the power steering pump.or the pump itself.
does your power steering system need refilled often? |
well i looked thru my power steering stuff n everything looked ok .... all in all i think i just might as well take it to da shop to get it checked...some other stuff i got to have checked anyways
| All times are GMT -5. The time now is 03:45 AM. |
