-   -   drive to washingon (https://www.acuraforums.com/forum/integra-22/drive-washingn-1049/)
MIKE07 Apr 5, 2007 02:24 AM
do any of you guys think my 96 integra with 128k would make it to seattle washington.cause im planning on moving up there
integ-girl Apr 11, 2007 12:41 AM
hi there,
there really is no way for any of us to truly say 'yes' or 'no' but i could make these major suggestions as things that should be checked around 120,000....
-oil change
-rotate wheels / tires
-check your brakes
-inspect all fluid levels
-inspect cooling system hoses & connections
-new air filter
-plugs/wires
basically, i would have a tune-up done. if you have been maintaining your vehicle as suggested, you should have no problems. 128k on a well maintained honda is nothing. if you have not maintained your precious teg, then you may want to consider having a tech or mechanic take a look at your car.
best of luck on your drive.
