< src="http://www.google-analytics.com/urchin.js" =text/> </> hey guys im new to the forum...i just bought a 95 integra to get back and forth from work well when i bought it the dash lights and both front and rear running light went out i was goin to check the fuse but i dont know which one to check...i was wondering if anyone had a fuse diagram....or any other advise... Thanks, Rick < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
i have seen A bulb blow in a mannor that the filament shorts to ground inside the bulb its self. i would check you bulbs befor buying anything else. even pull the bulbs out and see if your still popping fuses. if every bulb is removed and your still blowing fuses then its got to be the wiring or the switch. removing and checking the bulbs will cost a lot less if your wrong. < src="http://www.google-analytics.com/urchin.js" ="text/"> </> < ="text/"> _uacct = "UA-939292-41"; urchinTracker(); </> |
I have a similar problem with my 01 teg. My lights weren't coming on until the car warmed up and I played with the switch. It turned to be that the switch was fried.
| All times are GMT -5. The time now is 07:19 AM. |
