-   -   can you eliminate the ac compressor belt? (https://www.acuraforums.com/forum/integra-22/can-you-eliminate-ac-compressor-belt-3645/)
solotrust711 Jul 22, 2009 04:48 PM
I have a 95 integra,the ac compressor is going the belt is 1 of 3 that connect to the torque pulley can i just eliminate the ac compressor belt if i cant replace the compressor right now? will it still run normal?
samsyabi Aug 6, 2009 03:29 AM
No, I don't think it will be normal then also.
leastinterested72 Aug 21, 2009 03:06 AM
Dont eliminate the Ac compressor belt.You may have trouble in running it later on. May be sound will come from that.
jenifer.kaif Sep 6, 2009 05:13 AM
I think that you should not take risk. may be after removing it will convert into bigger issue.
aliyork35 Sep 7, 2009 04:24 AM
Why dont u once consult a mechanic. He might help u with this.
